IC Tester
nielz
Joined May 4, 2017
26
Try to make an IC Tester by using LEDS in inputs and outputs and toggle switches to ignate the inputs ,by using IC data sheet to determinning bias bins positive and negative also inputs and outputs,by appling clock to input one by one and observing output led we can decide if that IC work or idle .
I wait your openions and discussions.
Thanks.
34,739
I did an IC tester many years ago on a DG Nova 2 minicomputer.
It would be easier using programmable logic such as a microcontroller and a data base of all ICs that you want to test.
My system was also able to ID unmarked logic ICs (purchased as grab bags at Ham Fests).
absf
Joined Dec 29, 2010
1,968
I doubt there's any one designing an IC tester for LSI SMD chips, as this is going to be a mega project.
If you're talking about 74xx/40xx logic chips in SMD footprint, there are chip adaptor sockets that would convert the small chips to stand .1" which is easy for the test points to be checked.
Is this project for hobby purposes or for marketing?
Allen
nielz
Joined May 4, 2017
26
Allen
Thanks Allen
This tobic is so old and many ideas supmmited ,but there is amazing desings we could use of it and modify it with new electronics one of this awesome designes issued in wireless world magazine- January 1973 ,the checker seems to be chip adaptor socket or like stamp tool covering the chip and test result appear on led desiblay above.
dl324
Joined Mar 30, 2015
18,306
HP had one too:
I have several and actually used one to troubleshoot a defective curve tracer that had a defective TTL chip in the circuit that controlled how many traces were shown.
An advantage of the HP10529A I referenced above is that it can test chips in circuit. You attach the clip to the device being tested with a known good device in the tester. It uses pulse stretchers to display differences.
I was going to try it on CMOS, but never got around to it.
absf
Joined Dec 29, 2010
1,968
In the 70s' the company called Global Specialties made the LM-1 logic monitor.
Now you still can find them here and here...
On the eBay site picture, it doesn't look very complicated... All the components look discrete and I dont see any SMD IC inside. May be someone here can figure out how to design one with similar functions.
Or you can just buy it for $29.00 to study how's the circuit inside works..
Allen
