I want to design a readout interface for an opto-electrical sensor
zensam khan
Joined Apr 19, 2020
Design a readout interface for an opto-electrical sensor operating in the photo-conductive
mode. Employ the source-follower action to provide a stable bias across the sensor. Photo-
current integration provision is needed along with a row-select provision. IPH-MAX=1nA. Choose
such an integration capacitor, which provides a VOUT-MAX=1V for a TINT=10usec.
WBahn
Joined Mar 31, 2012
33,315
This is Homework Help, not Homework Done For You. You need to show YOUR best attempt to work YOUR homework problem. That gives is a point from which to help you move a bit further past your immediate stumbling block.
