I want to build a 555
thingmaker3
Joined May 16, 2005
5,083
I've moved these posts into their own thread.
For clarification, do you wish to build a 555 equivalent from discreet components for educational purposes?
beenthere
Joined Apr 20, 2004
15,819
Have you got an LM555 datasheet? I believe it has block diagrams of the internal circuitry.
What portion must make sound?
And, by the way, an astable multivibrator includes, but is not limited to, an LM555. A clear statement of your project would be nice to have. If it is simply an audio frequency oscillator, then reengineering an LM555 is more effort than is necessary for the result. Three resistors, two capacitors, a lamp and an op amp will do the trick.
Audioguru
Joined Dec 20, 2007
11,248
Hi Bill,
An 8 ohm speaker has a peak current that is too high for your poor little 555.
Connect a current-limiting resistor to limit the current to "only!" 200mA.
Your LEDs won't light when they are connected upside down.
Wendy
Joined Mar 24, 2008
23,814
Picky Picky, actually I've built the former circuit many orbits ago, the 555 didn't get hot or anything, just wasn't very loud. I'll change the latter schematic to correct the LEDs, and I'll breadboard the former to verify (but I'll change the schematic anyhow for now).
An old fashioned 1K to 8 ohm audio transformer would pick the volume back in any case.
My Dad's favorite phrase about this time was "Turn it off". He liked his TV and we lived in the deep country, where anything could interfere. Thanks for pointing out my boner.
I've noticed .gif files look a LOT better for these applications.
Audioguru
Joined Dec 20, 2007
11,248
With a 9V battery, the output of a 555 is about 7.5V p-p into a 1k transformer winding. Then the power is only 14mW. Like a little earphone.
The output at 200mA is 4V p-p. Then an 8 ohm speaker in series with a 12 ohm resistor will have a power of 320mW, 23 times more than with the 1k transformer.
A little LM386 power amplifier produces a square-wave of 1.1W when it drives an 8 ohm speaker with a 9V supply.
