Hi all,
Please forgive me my ignorance of this is ridiculously silly but I’m learning by doing and just need a little guidance with the following from people with more experience...
Trying to repair an amp from my car and think I have hit a snag. I had a damaged trace and pad so I followed guides on how to scrape off a little solder mask to expose copper and then remake a trace.
The problem is that when I was checking the resistance of my repair to an input trace for a voltage regulator I noticed it now gives continuity to ground pads in the same area of the pcb.
I assume this is a short and that in error I have exposed a copper ground trace or plane on a lower layer in the board and now connected the input trace directly to ground. Does this seem likely???
This image from underneath the pcb shows a large square which in hindsight looks to me like a ground plane (from what I can find by google) I’m hoping I’m wrong but could do with some help to confirm.
If so, I assume I need to remove my repair, repair the solder mask I scraped off then use a different method to repair the input trace instead?
Any help greatly appreciated.
Mike
Mike
