I have an LED controller which, for my purposes, is a sealed black box. The LEDs strips are the typical 5050 SMD on a roll. They have a 12v positive and 3 ground signal wires. If would be great if I could feed the 3 grounds and the positive into the single color roll which just has a negative/positive wire.. But it is not that simple.
I tested the circuit against the battery ground. The 3 ground outputs read +6volts when the unit is 'off' and they are under a quarter volt when the unit is on. The 12volt line is always on. So I'm now wondering if I can have a circuit that waits for any of those lines to go low to then turn on the 12v to the additional LEDs.
I'm also puzzled why the 'grounds' would become positive 6Volts when the unit is off. That seems strange.
