I can not get the outout of this drive ic. I need help
Anwar85
Joined Feb 27, 2023
I use protuse to see the output signal of an ic driver :l6384
I connect all the input according to the datasheet but still i get no output at the booth terminal hvg and lvg . I hope someone find out the issues.
Thank you.
Papabravo
Joined Feb 24, 2006
22,116
Thank you.
It is likely that you did not carefully read and interpret the datasheet. How are we supposed to help without any information on what you have done like a schematic diagram or even a picture of what you have constructed.
