I need some help here engineers on digital circuits.I have done decoder but am stuck with sub circuits.
eddkim
Joined May 5, 2020
18
How do your labels correspond to the problem text? You have V0, V1, and V2. The problem says you have V1, V2, and V3.
Its just a labling error,thanks for alerting me.Otherwise the output should be alright
What you have already drawn is not neat. Neatness will allow you and others to follow the circuit more easily.
[/QUOTE
Any help will be appreciated.Thanks
eddkim
Joined May 5, 2020
18
Check again.
I don't know what logic you're trying to implement, but the circled gates look suspicious to me.
Okay basically its a general 3 to 8 decoder.Why do you feel there is some problem here?
Check again.
@Dennis could you please suggest the way you would have solved this task?.
The inputs are three c1,c2,c3 and A1,A2,A3.The decoder above will handle the speed between 0 to 7 as the output thats why i have 8 gates
dl324
Joined Mar 30, 2015
18,437
If your work wasn't so sloppy, you could see that you haven't drawn it correctly. Two gates are V0V1, two gates are V0V1V2, and one gate only has one input connected.
dl324
Joined Mar 30, 2015
18,437
Homework help doesn't work that way. We can offer guidance, but you have to do most of the work.
There's more than one way to solve this problem. Clearly your instructor has a method in mind. You need to show us what you've been studying so we can see what your instructor expects.
eddkim
Joined May 5, 2020
18
He didnt specify the method.If at all you give me the idea you have i will work on the easiest method.thats my truth table.
dl324
Joined Mar 30, 2015
18,437
I assume you're doing this on a computer. Why are you taking distorted pictures of your screen and desk/keyboard? You can take screen captures or print to PDF.
This makes no sense. If V=0, why are you showing V1, V2, V3 in the table? By definition, they're all 0's.
Is this the method that you're being taught? It would be helpful if you posted your lecture notes on decoders.
EDIT: Your tables would be easier to read if you reduced the column width:
You're probably doing what your instructor is doing. S/he doesn't get it either. Having unnecessarily wide columns isn't helpful.
EDIT 2,3: Corrected table again; now matches OP's.
eddkim
Joined May 5, 2020
18
EDIT 2: Corrected table.
This part of the truth table is just a part showing whether the accelaration is successfull or unsuccessful.
dl324
Joined Mar 30, 2015
18,437
The posted table is for V=0, why do you bother to show columns for V1, V2, and V3? They're all 0's. Showing irrelevant information isn't helpful.
eddkim
Joined May 5, 2020
18
Could you please guide me on what you have.I need the way to go so that i can work it out
VO is when the car is not moving mate
The calculations of this table is not part of the markings.It is used to calculate the rules on the main document
dl324 and Dennis what do you have for me about these task?
dl324
Joined Mar 30, 2015
18,437
Nothing until you provide the information I've asked for.
I'd be inclined to solve it using a Kmap with 6 variables. I doubt that your instructor has that in mind because you and he keep mentioning decoders. Besides, not many students could simplify a Kmap with 6 variables.
eddkim
Joined May 5, 2020
18
yea it needs to be a circuit.Thanks though
dl324
Joined Mar 30, 2015
18,437
This is what I meant:
It would have been twice the number of gates with your 2 input limitation, but doable. You just need to be able to solve a 6 variable Kmap.
EDIT: Updated logic diagram.
