I need some basic education on cordless tool motor
Emare
Joined Dec 8, 2017
23
Then it would point to the motor, can you remove the brushes and make sure they are not in contact with the comm?
Another test, is if you place a voltmeter on the leads and rotate the armature as fast as possible, it should generate.
Sorry I missed this reply. By reassembling the grinder and rotating the output shaft I was able to get .5 volts. Didn't get too fancy with a winder so it wasn't very fast. Does this give some clues to the grinders problem?
panic mode
Joined Oct 10, 2011
5,013
how do the windings look like? if they are discolored (dark) on the surface, motor was cooked and it is much worse below surface. in that case insulation is probably damaged and you are getting shorts.
Emare
Joined Dec 8, 2017
23
Thats the odd part, except for a little discolouration on the terminals on the 'electronic module' everything looks pristine!
