i need help with making a digital clock using 74192 and 7447 and seven segement
shirotpoison
Joined Mar 23, 2024
32
You shouldn't be able to see a count of 60 on the seconds counter.
Disconnect the AND gate on the 10 seconds counter and reconnect. Maybe you made edits that confused Proteus. I have had this problem with MultisimBlue and DigitalWorls. It only happened once on DigitalWorks, but numerous times with MultisimBlue. It seemed to forget that things were connected and I got into the habit of grabbing components and moving them around to make sure the wires were still connected. Don't have to worry about that now because MultisimBlue is no longer available.
i have a race glitch in the and gate so i cant counnect the secounds couters (1 and 2) with the munits counters (3 and4)
35,178
There is no race glitch in the AND gate. Something else is causing the simulator to give wrong results. It would be easier and quicker for you to breadboard the real circuit.
shirotpoison
Joined Mar 23, 2024
32
what is then the cause for counting from 00 to 40 without the RC circuit
in different site i saw some one call it a race glitch this is whey i add the RC circuit and it worked it start counting to 60 ,but i didnt know how to counnect the munits counter
35,178
It is a race glitch if you can show evidence that it is a race glitch. Adding an RC circuit that "fixes" the problem is not evidence that it is a race glitch.
Connecting to the minutes counter is a completely different issue that is trivial to solve.
35,178
In CircuitMaker 2000, look under the Simulation tab and choose Digital Mode.
You were correct after all and we were wrong. There is a glitch at the AND gate output when the counter transitions from 3 to 4. Your circuit simulator is faster and does capture the glitch. CircuitMaker 2000 does not capture the glitch.
shirotpoison
Joined Mar 23, 2024
32
is this glitch will appear when i do the circuit on the breadboard
35,178
I cannot give you a definitive answer for that. It depends on a number of factors, in particular, the family of digital logic used in your circuit. Let us say that the potential for a glitch to occur is there. Your RC filter is one possible solution as it filters out a short pulse. A delay of Q2 gets rid of it entirely.
