I Need help with designing a PCB.
norvegicum
Joined Apr 24, 2017
7
Dear Members,
I need help to redesign a circuit from 20 years ago.
I would like to make it smaller and improve on functionality.
I am however not an electronic engineer, so if someone here can help me out, it would make me a happy man.
I would like to add display and timer-program, swap the 9V battery(ies) with one rechargeable Li-Battery, and fit this into a watch-size case. Am i dreaming?
AnalogKid
Joined Aug 1, 2013
11,037
Yes. While Apple has demonstrated what you can do inside a watch case if you have lotsa money, I don't think you have enough. In terms of complexity, a better example would be a digital watch. Casio builds hundreds of thousands of them each year and sells them for almost pennies, but development costs run around $500K for each basic mechanism.
The circuit is a reworked version of the Beck blood electrifier. Once you crank up the digital electronics needed for a display and timer, you can add in the 4 Hz oscillator with more firmware. You'll still need an H-bridge driver. Nothing will beat the LM358 for size and cost, so the net savings is one capacitor and one resistor. Next up you'll need an 8:1 boost converter, which is not a very efficient circuit when the source voltage is so low.
Of course it can be done, but once you work up a prototype you'll see the packaging problem.
ak
MaxHeadRoom
Joined Jul 18, 2013
28,682
If you get as many items in a SMT format in place of through hole, it will reduct the size considerably, just a little harder to put together.
Max.
norvegicum
Joined Apr 24, 2017
7
Max.
yes. SMT is a must. Im not sure though if all of the components i used when i made my bords manually are available in a smaller size. The pot-meter has to be changed for buttons instead. That means changes to the circuit.
norvegicum
Joined Apr 24, 2017
7
ak
norvegicum
Joined Apr 24, 2017
7
ak
Thanks, yeah beck signal generator. i use it for many different applications and havent found a version that i like. we are not talking apple-complexity. I would like an on/off+timer-program of say: 30min increments, and power output from 0-10, and a simple display that shows setting. How small do you possibly see this with the booster, battery, display with SMT-build? Would you like to help me out?
AnalogKid
Joined Aug 1, 2013
11,037
Power output from 0-10 - the Beck circuit has a constant voltage fed through a variable resistor. Do you want to keep that, or have a fixed resistance fed by a variable voltage? The current through the load is the same either way (except in the millisecond near the transitions), but the output impedance will be significantly different.
ak
norvegicum
Joined Apr 24, 2017
7
ak
Keep the voltage(or both). see the pic of the old PCB. Im not sure of the implications on the different impedance for the applications i intend to use it.
