Hey everybody,
one of the sub-circuits in my mini project in logic design course needs to do an addition between two binary numbers, 4 bits each one, and then to display the result on 7-segment (Left digit and Right digit separately). I need to perform the addition only when "Level_Win" equals to '1'.
The difficult part for me is that the two numbers are coming from the same outputs (need to add between the previous number and the current number) depends on clock & Level_Win.
EDIT: in the circuit, MSB means right digit and LSB means left digit.
I tried to build the following circuit, but it does not work well:
Any ideas & tips to fix this are welcome!
Thanks in advance!
Thanks in advance!
