I need help looking for DC generator
zemanekj
Joined Jan 31, 2019
58
I am looking to buy or make a DC generator, something that can generate, say, up to 35 volts volts.
However I am not looking for something that can only generate maybe 1-2 volts tops like in this link:
https://www.amazon.com/gp/product/B078MSFFH5/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
(I know I says they can generate 3-12 volts but none of them have lived up to that claim) I am however looking for a generator with a similar design.
Any suggestions?
MaxHeadRoom
Joined Jul 18, 2013
30,817
Do you need it regulated?
Any DC motor should be able to generate DC, if you find a wound field version, you could regulate it easily.
Max.
danadak
Joined Mar 10, 2018
4,057
What power/current do you need at 35 Vdc ?
What is turning the generator shaft ? RPM would be one question.
One possibility is to use a 24 V alternator and raise its field excitation,
but I am not sure how much the field will tolerate in terms of excess V
and how well the alternator is operating with respect to its magnetization.
Regards, Dana.
MaxHeadRoom
Joined Jul 18, 2013
30,817
A 12v alternator would also put out the small current the OP needs, but a bit overkill.
You can get 48v+ from as 12v alternator.
Max.
mvas
Joined Jun 19, 2017
539
Any suggestions?
What voltage did you measure across that Generator's output when you were spinning the shaft at 6,500 RPM?
