I need help in my electronics project
mo1998
Joined Jun 18, 2019
this is the description of the required project is in pdf file
this is the circuit that i have designed and the output signal.
the problem that the wave shape is not correct ,so i need help to make it correct?
WBahn
Joined Mar 31, 2012
33,323
What is wrong with the waveshape?
Which part of the circuit is responsible for making the waveshape what it is supposed to be?
It looks like you through the entire design together and then tried to see if it happened to do exactly what you wanted.
Instead, design each stage to accomplish a specific function and then test whether or not that stage adequately performs that function.
