What i am trying to accomplish is driving a dc motor with outputs from a cnc breakout board that will be used for an automated sander.
First step zero axis's.
Second step Y- moves in y+ direction z is up at this point.
Third step z descends to work surface.
Fourth step Y axis starts moving in y- direction , sanding occurs at this point.Yea the wood dust is flying!!!
Fifth step back to first step.
Yea just back and forth and up and down with pauses in the y axis movement at the end of each y- and y+ , this gives the z axis time to go up or down as needed.
The software driving the breakout board is Mach 3, the breakout board is a cheapy 5 axis break out board purchased through (Stepperonline.)
The dc motor i'm using is a Dayton Geared dc motor Part #8HK98, develops lot's of torque,the reason i would like to stay with using this motor.came off of original conveyor belt used to move the wood under the sanding drum.
Keep mind that the breakout board switch's only 0 and 5 volt values.
Of course i will use the the y- and the y+ to forward and reverse the motor using a 2 relay module made for arduino and pic applications, as well as dedicated relays for forward and reverse movement of y axis. NO problem there.
I think i will have to use a relay to start and stop y movement while the z axis is moving up or down?
Keep in mind i do have the unused x axis which i can use for signal manipulation if needed.
Thanks for any help on this matter
Oh and by the way i'd like to say HI my name is Charlie.
