panic mode
- Joined Oct 10, 2011
- 4,988
TS never actually said positive pulse, however read post #11.since the original post asked for a positive pulse, solutions with capacitors will need to be flipped.:
Yeah, sorry about that. I tend to forget them. I usually put arches across connections that are not connections.circuit in post 6 lacks connection dots making it hard to follow.
Those "arches" indicating no connection have a real benefit that even on the third or fourth copy they are still visible as crossings without connections.Yeah, sorry about that. I tend to forget them. I usually put arches across connections that are not connections.
That's for sure. Some have complained that the arches are old school, archaic and out of date. I've liked them for years. Not having to draw in dots at all the intersecting connections while not specifying a connection every time a line crosses another.Those "arches" indicating no connection have a real benefit that even on the third or fourth copy they are still visible as crossings without connections.
That was done a couple generations ago.By the time a drawing has been photo-copied 3 times every junction has a dot.
Generally those I deal with don't have one anymore either!Neither a photocopy nor a landline fax can transfer any malware, and that is a valid reason to use them.
