Thanks but what should be a better solution that can solve the problemHello,
Do you realize that you are talking about 6 kWatt of power?
You will never find a circuit for the full voltage range you want.
A switched powersupply will not reach 0 Volts.
A linear power supply will have to dissipate a lot of power and is very inefficient.
I want to designAre you looking to design or buy an off the shelf solution ?
Regards, Dana.
https://www.ebay.com/p/Xantrex-XDC-300-20-Digital-DC-Power-Supply/14015449457?iid=232939986993Please need a 0v to 300v DC circuit 20amps
No. Even if you found a diagram of a circuit to do what you're asking, building the circuit and getting it to work reliably would be a major challenge, given the power level involved.is there a section in this forum where someone can search for only circuit diagrams without posting a thread
I get the impression that you are actually asking someone here to do the design for you . The fact that you are asking members here for help suggests that you will need a lot more electronics experience before even beginning the design process yourself. As you can infer from the above posts, a design of this sort is not trivial.I want to design
