MisterBill2
- Joined Jan 23, 2018
- 28,566
Actually, there could be a resistor or even a diode across the power supply so that the capacitor could discharge around the loop. But as I think about it the polarity would be wrong, so it would have to be a resistor across the supply. The diode will need to be across the sonalert device to protect it from reversed polarity. A 1K resistor would waste 12 milliamps with the supply on, and you could replace the resistor with a 12 volt filament light bulb for a faster discharge and also a visual reminder that the power was back. But still this concept will be much simpler than the one with the timer chip. RC time constants can be very useful even in some funny circuits like this one.Here's a schematic of the Sonalert circuit.
It adds a diode and bleeder resistor, such that the bleeder resistor current does not go through the Sonalert after the capacitor is charged, to avoid the problem Tony mentioned.
The value for the capacitor and bleeder resistor may need to be adjusted, depending upon how much current the Sonalert you select requires, and how fast you want it to recover after the power goes out.
