Just make sure you connect all the pluses together.Okay, would try out and see if it improves.
Sorry, what do you mean by pulses?Just make sure you connect all the pluses together.
Not pulses, pluses.what do you mean by pulses
Oh, okay. Yeah sure.Not pulses, pluses.
I meant keep all the plus connections on the chargers and battery together.
Thanks, but can't find 12/24 volts switch. Just the "Standard / Sealed" and "Other / Bike" switches on this one.
Hello, I found a very old heavy 5000va Stabilizer at my dad's place and it was all rusty and the coverings are falling apart. I looked inwards and found a massive Transformer inside. This Transformer is really big and heavy. I can't tell what the rating is but it's twice the size of the one in my 8amps charger.20Adc would require a large and expensive transformer rated for about 20V, 40Arms, along with some high power circuitry.
Price such a transformer and get back with us, if you still want to do that.
Why do you want to charge the battery so rapidly?
Thanks... I tried putting the charger on my 12v battery which was at 12.5v with a voltmeter, and for like one hour plus.. the volt meter was shuffling between 12.5v and 12.6v. Then i just assumed the charger isn't good so it doesnt ruin my battery.It probably is ok. Just unfiltered, so your meter may not read higher. See how the battery volts and amps read with the charger on the battery. But it could be faulty. Running half wave with a crook bridge.
Have a go at tracing the circuit.
Thanks Les. Would do that.The voltage fluctuation could be caused by your mains supply voltage varying. Monitor the mains voltage at the same time as monitoring the battery voltage. (Or charging current.) I am assuming the charger is just a simple transformer and rectifier with no voltage control circuit.
Les.
Okay. In place of the Analog Voltmeter and Ammeter, I can replace with a Digital Voltmeter/AmpMeter ?It had a circuit breaker in it but that has been disconnected. Probably broken too.
The first thing to do is to rewire the charger. Mount the rectifier heat sink and generally clean it up.
You could, but if the old meters work, is there any reason to?In place of the Analog Voltmeter and Ammeter, I can replace with a Digital Voltmeter/AmpMeter ?
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
