I can't read this potentiometer symbol even if my life was on the line
spikespiegelbebop
Joined Nov 30, 2021
163
Well, this question may be silly, but I've been searching for half an hour about this potentiometer symbol, I can't find a reference anywhere. What does the circle stand for, GND? VCC? Geez...
Papabravo
Joined Feb 24, 2006
22,070
It is common in symbols used by simulators to indicate a positive direction for current. In a real component there is no significance.
Ian0
Joined Aug 7, 2020
13,117
The anticlockwise end (or was it the clockwise end?) - depends on which side you were looking at it from.
WBahn
Joined Mar 31, 2012
32,777
It generally used to indicate which end of the resistor the wiper moves to when it is turned clockwise (as seen from the viewpoint of someone looking down on the screw/dial as it is turned). You will sometimes see "CW" instead of the circle.
Sometimes it doesn't matter (e.g., a hobbyist/experimeter will simply turn the pot in the direction that causes the desired behavior).
Sometimes it's important for user convenience (e.g., a user generally expects the volume to increase when the knob is turned clockwise).
Sometimes it's critical (e.g., the pot is part of a feedback circuit, such as position indication).
WBahn
Joined Mar 31, 2012
32,777
The o is the final Anti Clockwise position of the pot.
I've generally seen them as being at the most clockwise position, but that's possibly a reflection of the pots I happened to use. The CCW makes some intuitive sense in thinking of that position as being zero and interpreting the circle as a zero. I've been looking around the web and haven't been able to find any references for either case. There mere fact that both conventions are used make it a largely useless convention. I definitely prefer the CW (or CCW annotation).
Ramussons
Joined May 3, 2013
1,568
By age old practice, the "increase" has always been clockwise - whether Gain or Attenuation.
34,714
The dot has nothing to do with the voltage since that depends on circuit application.
The dot represents pin-1, as with ICs, connectors, etc, i.e. fully counter clock-wise (CCW) position.
