Hi. I ve’got a little (not) misunderstanding of my code. All I had to do was follow a button, “jump over” its ringing and see if it’s pressed. I wrote this code in button library:
And this in main:
When I press the button, it works just fine:
But…Here we go. When I hold it and it goes inside if (new interruption), the counter is not ‘1’, but ‘0’. Why? Code itself didn’t make it zero (Button is still being held).
- MPLab X IDE v5.25;
- XC 8 v2.10
- PIC16f1788;
- PICkit v3.
Code:
typedef struct{
uint8_t Index;
uint8_t Counter;
bool WasPressed;
bool IsBeingProcceed;
bool IsShortPress;
bool IsLongPress;
} Button;
void ReadButton(Button btn){
//btn.WasPressed=false;
//ButtonsPort = 0;
ButtonsPort = ~PORTC;
if ( (ButtonsPort & (1<<btn.Index)) && (btn.WasPressed==false) )
btn.Counter++;
if(btn.Counter > 20 )
btn.WasPressed = true;
btn.Counter = 45;
if( !(ButtonsPort & (1<<btn.Index)) && (btn.WasPressed==true) )
btn.Counter = 0;
btn.IsBeingProceed = false;
bool IsButtonPressed(Button btn)
if (btn.WasPressed == true && btn.IsBeingProceed != btn.WasPressed)
btn.IsBeingProceed = true;
return true;
else
return false;
And this in main:
Code:
void TMR0_DefaultInterruptHandler(void){
ReadButton(Minus);
if( IsButtonPressed(Minus) )
v2+=5;
v1=v2-43;
- XC 8 v2.10
- PIC16f1788;
- PICkit v3.
