I am new with electronics and I would new some quick explanation.
lukamlakar
Joined May 21, 2019
Here is the question. The output voltage of an microcontroler is 3.3 V and max current is 100mA. How many LEDs we can wire together in series if we use 250 ohm resistor after each one. LEDs conductive voltage is 1.8V.
I know that if we wire resistors in series we must sum together the resistance of resistors. But i do not undertstand were i can use provided conductive voltage and max current. I hope you understood the question( my english is not the greatest). Thanks in advance :)
Ya’akov
Joined Jan 27, 2019
10,357
Welcome to AAC.
If you wire the LEDs in series, you must add up all the voltage drops, so after two you will not be able to supply enough voltage to them any more.
What are you actually trying to do?
lukamlakar
Joined May 21, 2019
Welcome to AAC.
Its a homework quiz. Possible anwsers are 12, 14 ,16, 18.
WBahn
Joined Mar 31, 2012
33,326
Drop the course and enroll in a reputable school. :D
Hopefully either you haven't conveyed the problem correctly or the person that wrote it made a mental goof.
Are you sure that the question doesn't have a bunch of parallel branches in which each branch consists of one LED and one 250 Ω resistor in series? That would make a lot more sense.
What is the EXACT wording of the question?
djsfantasi
Joined Apr 11, 2010
9,237
Assuming that the micro controller is going to use one led per pin, how much current does each pin need to supply. Figure it out for one pin first.
You know everything you need to do this. The source voltage is 3.3V. What does each LED drop? Then you have a 250 ohm resistor. What is the current through the resistor? What law of electronics is important here? Show us how you would apply it...
The final steps should become obvious once you successfully answer the questions above.
WBahn
Joined Mar 31, 2012
33,326
TS still has to show how to arrive at the correct answer and most of this was revealed in post #11.
Actually, all the TS has to do is select the correct answer on this multiple choice quiz. I don't see anything that indicates that credit on the quiz is contingent on showing any work at all. It's likely an online quiz.
The information in Post #11 gives a solid roadmap, but the TS can't get the answer to the quiz with it unless they understand the concepts well enough to follow that roadmap to get to the destination.
WBahn
Joined Mar 31, 2012
33,326
Sure hope the TS isn't the one designing my pacemaker after they graduate :)
Let's be fair -- the TS didn't ask to be spoon fed the answer to his quiz problem (unlike so many of the folks that come here). Also, we don't know what level the course he is taking is. I'm guessing it's at the very beginning of his educational program and that this is all very new to him.
