i am new to basic electricity
Koky
Joined Feb 27, 2010
3
4 loads are connected in series across 120volts and 3 ampere current exists.one load fail to perate.the voltage across each divece is 40 volts.what circuit fault is indicated?
bertus
Joined Apr 5, 2008
23,026
If the voltage accross each remaining element is 40 Volts.
How many volts are there accross the "defective" element?
What is wrong with the "defective" element?
Greetings,
daviddeakin
Joined Aug 6, 2009
207
It sounds like the answer must be "short circuit". An open circuit would result in 0V across each device.
