i am designing a 30v input dc-dc push-pull converter
phuczdfsd
Joined May 13, 2025
6
tôi đang thiết kế bộ chuyển đổi Push-Pull dc-dc điện áp vào cỡ 30v điện áp ra cỡ 10v sử dụng ic LTC3723-1 làm bộ điều khiển. tôi thiết kế bộ giới hạn điện sử dụng TL431 và PC817 nhưng tôi không chắc rằng thiết kế phần cứng của tôi chính xác.mọi người có thể giúp tôi nhận xét không.
Google translation:
i am designing a 30v input dc-dc push-pull converter 10v output using ic LTC3723-1 as controller. i am designing a power limiter using TL431 and PC817 but i am not sure that my hardware design is correct. can anyone help me with comments.
Please use only english over here!
ronsimpson
Joined Oct 7, 2019
4,829
Why the TL431? It looks like you want to shutdown U1 when the output is too high voltage.
I think U4 will cause error in the voltage regulation.
You could try pulling SS pin low to do the same job. (now you pull FB high)
ronsimpson
Joined Oct 7, 2019
4,829
I would use the LTC3723. It also has current limiting.
The LTC3723 is much newer and faster. Running faster allows a smaller transformer.
The CG2524 does not use the error amplifier well in this configuration. It relies on a Zener diode for regulation and temperature stability.
Ian0
Joined Aug 7, 2020
13,286
Why do you have two feedback connections? One direct to the error amplifier input on the FB pin, and one via a TL431 which is isolated via an opto, even though there is nothing to isolated it from.
ONE feedback connection is enough!
Your TL431 will almost certainly be unstable as you do not have a capacitor between REF and CATHODE.
If your circuit is meant to be isolated, remove the voltage divider to FB, and connect the opto to COMP where is should go.
If it is not meant to be isolated, remove the TL431 and opto.
There's a good reason they publish application circuits in the datasheet. . . .
phuczdfsd
Joined May 13, 2025
6
[TRÍCH DẪN="Ian0, bài viết: 1983404, thành viên: 719943"]
Tại sao bạn có hai kết nối phản hồi? Một kết nối trực tiếp đến đầu vào bộ khuếch đại lỗi trên chân FB và một kết nối qua TL431 được cách ly thông qua opto, mặc dù không có gì để cách ly nó.
Chỉ cần MỘT kết nối phản hồi là đủ!
TL431 của bạn gần như chắc chắn sẽ không ổn định vì bạn không có tụ điện giữa REF và CATHODE.
Nếu mạch của bạn cần được cách ly, hãy tháo bộ chia điện áp khỏi FB và kết nối bộ quang với COMP, nơi cần kết nối.
Nếu không cần cách ly, hãy tháo TL431 và opto.
Có một lý do chính đáng để họ công bố các mạch ứng dụng trong bảng dữ liệu. . . .
[/TRÍCH DẪN]
Tôi muốn thiết kế bộ giới hạn điện áp đầu ra cho hệ thống nhưng kết nối TL431 và PC817 của tôi với bộ điều khiển không chính xác. Bạn có thể giúp tôi kết nối bộ phận này không? Cảm ơn
ronsimpson
Joined Oct 7, 2019
4,829
Add resistor of 3 kOhm from TL431 cathode to "output" to maintain load for TL431
Learning exercise:
A TL431 needs 1mA of current to work properly. See datasheet. (1mA to 100mA)
When "out" is low there should be no current in U4. The new resistor Pyrex wants needs to supply the TL431 with 1mA or more of current. The resistor should limit the current when the TL431 is pulling down as hard as it can.
ronsimpson
Joined Oct 7, 2019
4,829
Translated:
[QUIZ="Ian0, posts: 1983404, members: 719943"] Why do you have two feedback connections? One goes directly to the error amplifier input on the FB pin, and one goes through the TL431 which is isolated via the opto, even though there is nothing to isolate it. Just ONE feedback connection is enough! Your TL431 will almost certainly be unstable since you don't have a capacitor between REF and CATHODE. If your circuit needs isolation, remove the voltage divider from the FB and connect the opto to COMP where it should be connected. If isolation isn't needed, remove the TL431 and opto. There's a good reason they publish the application circuits in the datasheet. . . . [/QUIZ] I want to design an output voltage limiter for the system but my TL431 and PC817 connection to the controller is not correct. Can you help me connect this part? Thanks
phuczdfsd
Joined May 13, 2025
6
[TRÍCH DẪN="ronsimpson, bài viết: 1983467, thành viên: 653142"]
Vui lòng đính kèm tập tin SPICE của bạn.
Chúng tôi sẽ giúp bạn.
Bạn muốn điều gì xảy ra khi điện áp OUT quá cao?
[/TRÍCH DẪN]
thiết kế mạch giám sát đầu ra ( Vout ). Khi Vout vượt quá một ngưỡng đã được xác định rõ ràng (12V), mạch này sẽ kích hoạt để tắt bộ biến đổi
ronsimpson
Joined Oct 7, 2019
4,829
Problem: Error amplifier.
See attached file. You will need to change TL431 to TL431ED.
I tried changing U4 to connect to SS but not good.
I also changed transformer inductance 2X and inductor 2X.
I hope this helps you.
Plamen
Joined Mar 29, 2015
111
Google translation:
The TL431 use is classical. Exactly in the FB to provide negative voltage feedback.
The circuit appears drawn in LTSpice. It could be simulated there to find how well it works
Ian0
Joined Aug 7, 2020
13,286
You use TL431 when you want an isolated feedback.
You use a resistive divider to the FB input when if there is no need for isolation.
You use both if you want to make a real shambles that doesn't work.
phuczdfsd
Joined May 13, 2025
6
[TRÍCH DẪN="ronsimpson, bài đăng: 1983515, thành viên: 653142"]
Sự cố: Bộ khuếch đại lỗi.
Xem tệp đính kèm. Bạn sẽ cần phải đổi TL431 thành TL431ED.
Tôi đã thử thay đổi U4 để kết nối với SS nhưng không được.
Tôi cũng đã thay đổi độ tự cảm của máy biến áp là 2X và cuộn cảm là 2X.
Tôi hy vọng thông tin này có ích với bạn.
[/TRÍCH DẪN]
tôi vừa xem qua mô hình này trong bảng dữ liệu của nhà sản xuất. nhưng khi tôi mô phỏng thì không thể được, bạn có thể xem giúp tôi không? Tôi muốn sử dụng LT1431 và MOC207 để ổn định điện áp ra và So sánh điện áp phản hồi tại chân FB với điện áp tham chiếu nội bộ, sóng đại sai lệch và tạo ra tín hiệu điều khiển cho bộ điều chỉnh chế độ xung. Mạng bù đảm bảo ổn định và định hình đáp ứng của ứng dụng điều khiển vòng
ronsimpson
Joined Oct 7, 2019
4,829
I cannot translate your text this time. Many words do not work for me.
Red arrow points at the error. R21 should connect to Vref not DPRG.
ScottWang
Joined Aug 23, 2012
7,505
If you continue to post the non-English then you may get banned from this site.
User Agreement.
8.
AAC is an English-only site. Although AAC is global in its membership, it is maintained as an English-only site in order to foster universal communication among its members and readers, which includes not only those participating in a particular discussion, but those who might wish to read the discussion years from now as the result of a search.
Consequences of Failure to Adhere to the All About Circuits User Agreement
We do not expect anything less than full co-operation with the rules outlined. If You break a rule, expect consequences. Depending on the circumstances an infraction will result in a standard warning and an e-mail or PM from the Moderating Team. In more severe circumstances the account will be permanently removed from the system and the IP address banned.
These User Agreement are available from the bottom of every page on the All About Circuits Forums.
User Agreement.
https://www.allaboutcircuits.com/user-agreement/
phuczdfsd
Joined May 13, 2025
6
i just looked at this model in the manufacturer's datasheet. but when i simulate it i can't, can you help me? i want to use LT1431 and MOC207 to stabilize the output voltage and Compare the feedback voltage with the internal reference voltage, the bias wave and generate the control signal for the pulse mode regulator. The compensation network ensures the stability and shaping of the loop control application
