Hybrid Solar and Hydroelectric Power Generation
Daisa
Joined Jun 2, 2018
5
Hi, I am building a solar and hydro powered water meter. Do you have any ideas on how to isolate the two sources, where only the one with the higher voltage will work? I will greatly appreciate your help. Thank you!
oz93666
Joined Sep 7, 2010
742
" a solar and hydro powered water meter"!!! ..... What's that ???
You wan't "only the one with the higher voltage to work" ... that seems a bit wasteful , the plan must be to extract energy from both sources it , should be possible....
Give lots more details ....
Daisa
Joined Jun 2, 2018
5
oh, I didn't know that was possible. It's because I was told that if they both work together, the output voltage may be averaged. My solar panel has an 11v max output voltage while the water turbine generator has a max output of 12v. I am going to use this to charge a 3.7 lithium ion battery.
Alec_t
Joined Sep 17, 2013
15,167
For safety's sake, buy a ready-made lithium battery charger which will accept the maximum input voltage from either source.
The two sources could be coupled to the charger input via respective diodes. This arrangement forms an 'OR' gate which allows the higher voltage source to drive the charger.
camerart
Joined Feb 25, 2013
3,874
Did you use the word meter incorrectly? Do you mean charger.
I'm pretty sure if you connect them both in serial, you will get better results.
As mentioned be careful about charging lithium batteries.
Give some power information amps/watts
Camerart.
wayneh
Joined Sep 9, 2010
18,184
This is the answer. It's very common to "OR" power sources together and all you need are diodes to protect each source from current being driven backwards through them by the other source. Given your low voltages, I recommend Schottky diodes (ex. SB540) because they will show a lower voltage (and thus power) drop across themselves.
Don't bother designing your own charge controller - use a ready-made one as recommended.
Bernard
Joined Aug 7, 2008
5,784
If 11 v is the max. solar, then rated V will be around 8 V which contribute little in charging.
Li charger input V might be around 5 V so a buck converter might be needed.
What are the power levels of the two sources?
Daisa
Joined Jun 2, 2018
5
Hi, my solar panel is 5.5V 200ma. We have 2 that we connected in series. And it is able to give around 10+ volts. Then I used a buck boost converter to give a 5v output. But it was not able to charge the lithium ion battery that is connected to a powerbank module. Is the current a problem here?
Daisa
Joined Jun 2, 2018
5
Thank you!
Daisa
Joined Jun 2, 2018
5
