Hybrid Moped Dual power source lights and diodes
BruceLindholm
Joined Feb 15, 2018
5
Hi All,
I am building a hybrid moped - gas engine power to the rear wheel - 48v power to a front hub motor. It all works well except I am unsure of how to design the circuit for the headlight and tail light. The bike has a lighting circuit to power the lights - it also has a rectifier so the light uses 12v dc power. I have a 36w dc-dc converter to have 12v power out of the 48 v battery. I want to have the lights work on engine power only, battery power only, and also if both engine and battery power are being used - and all through a single switch. I believe I need a diode on the 12v output of the dc-dc converter, but don't know if I need one on the positive side of the lighting circuit. Is there anything else I am missing?
Thanks for any comments or help you can provide.
Bruce
wayneh
Joined Sep 9, 2010
18,162
If I understand correctly, you need only the one diode because the rectifier already contains diodes to prevent reverse current.
You are OR-ing power supplies together, and the typical solution is a diode for each supply to prevent reverse current being driven into that supply. As I said, I think your rectifier already does that for the moped's built-in electrical system. Does your moped have a magneto-based power system? I've never seen one with an alternator.
Does the 48V battery get recharged by the moped's electrical system, or is that separate?
BruceLindholm
Joined Feb 15, 2018
5
It is a magneto based system. The gas engine will charge the 48v lithium battery above a certain voltage. Thanks for your response - it was helpful.
wayneh
Joined Sep 9, 2010
18,162
How does the built-in lighting system get it's 'normal' 12V supply when running? Was the DC-DC converter also built-in?
