Hi J,'PIR1.CCP1IF = 0 should be uncommented
128 take away: index=index+1
It was my mistake.
Hi J,In #66 you had: toggle RD0
You can use whatever pins are available.
'18F4431 32MHz XTL REMOTE_SLAVE 030123 0930 TEST
Define CONFIG1L = 0x00
Define CONFIG1H = 0x06 '8mHz x4 =32
Define CONFIG2L = 0x0c
Define CONFIG2H = 0x20
Define CONFIG3L = 0x04
Define CONFIG3H = 0x80
Define CONFIG4L = 0x80 'Set for HVP
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
'Define SIMULATION_WAITMS_VALUE = 1 'Comment in for SIM out for PIC
Define CLOCK_FREQUENCY = 32
Define SINGLE_DECIMAL_PLACES = 2
Dim m2s(4) As Byte
Dim s2m(4) As Byte '0=s2m(0), 1=s2m(1), 2=Batt volts '10s', 3=Batt volts 'units'
Dim datam2s0 As Byte 'At the moment QEIDEG is being used CHANGE later.&
Dim datam2s1 As Byte 'At the moment QEIDEG is being used CHANGE later.&
Dim datam2s2 As Byte
Dim datam2s3 As Byte
ANSEL0 = 0 '%00000000
ANSEL1 = 1 '%00000000
Symbol slave4431_cs = PORTC.6
TRISA = %11011000 '7=OSC, 6=OSC, 4=QEIB 3=QEIA 2=TEMP SEROUT
TRISB = %00000000
TRISC = %01000100 '6=1-slave4431_cs, 2=MOSI
TRISD = %00000000 '6=led, 7=led
Symbol rled = PORTD.6
Symbol yled = PORTD.7
'START:
yled = 1
rled = 1
WaitMs 1000
yled = 0
rled = 0
WaitMs 1000
yled = 1
rled = 1
WaitMs 1000
yled = 0
rled = 0
WaitMs 1000
'*********** SETUP SERVO *************************************
Dim index As Byte
Dim motor_servo(8) As Word
Dim time_now As Word
Dim time_set As Word
Dim shift_reg As Byte
'********** END SETUP SERVO **********************************
WaitUs 100
Hseropen 9600 'After initialisation
Hserout "Ready!4431", CrLf
'Init spi
Call init_spi() 'initialise spi -here SSPEN=1 sets the pin directions for SPI
'Set them from your program as needed.
motor_servo(0) = 0300 'MIN 0300 max 2200 'Port bit 0, Near min position
motor_servo(1) = 1500 'Port bit 1, Mid position
motor_servo(2) = 2300 'Port bit 2, Near max position
motor_servo(3) = 1300 'Port bit 3, Under mid position
motor_servo(4) = 1700 'Port bit 4, Over mid position
motor_servo(5) = 1200 'Port bit 5, etc
motor_servo(6) = 1900 'Port bit 6
motor_servo(7) = 1400 'Port bit 7
'T1CON = %00011111 '0x31 '8:1, switch on REFERENCE REMOVE
T1CON.T1CKPS1 = 1 '11 = 1:8 Prescale value
T1CON.T1CKPS0 = 1 '" " "
T1CON.T1OSCEN = 1 '1 = Timer1 oscillator is enabled
T1CON.T1SYNC = 1 'Do not synchronize external clock input
T1CON.TMR1CS = 1 'External clock from pin RC0/T1OSO/T1CKI (on the rising edge)
T1CON.TMR1ON = 1 'Enables Timer1
'Without an output pin defined, just an interrupt from CCP
'CCP1CON = 0x02 'ccp_compare_toggle
'CCP1CON = %00001001 '0x09 Compare mode; initialize CCPx pin high; on compare match, force CCPx pin low (CCPxIF bit is set)
CCP1CON.CCP1M3 = 1 'Compare mode; initialize CCPx pin high; on compare match, force CCPx pin low (CCPxIF bit is set)
CCP1CON.CCP1M2 = 0
CCP1CON.CCP1M1 = 0
CCP1CON.CCP1M0 = 1
'And enable the interrupts for the hardware used
'the reference for CCP1, so no time interrupt required.
PIE1.CCP1IE = 1
'INTCON1.PEIE = 1 'INTCON bit 6'ADDED #81 &
'INTCON1.GIE = 1
INTCON.PEIE = 1 'INTCON bit 6'ADDED #81 &
INTCON.GIE = 1 'CHANGED &
'NOTE, line from old program CCP1IP = 1 'High Priority interrupt for CCP1
main:
'motor_servo(0) = 2200 'MIN 0300 max 2200 'Port bit 0, Near min position
'Toggle rled
'WaitMs 10
s2m(0) = 10 'TEST DATA1
s2m(1) = 11 'TEST DATA2
s2m(2) = 12 'TEST DATA3
s2m(3) = 13 'TEST DATA4
'SSPBUF = s2m(0)
'qeideg.LB = m2s(0)
'While slave4431_cs = 1 'Waiting till CS goes ON =0
'Wend
'While Not SSPSTAT.BF
'Wend
'SSPBUF = s2m(1)
'qeideg.HB = m2s(1)
'Wend
'Wend
'SSPBUF = s2m(2)
'datam2s2 = m2s(2)
'Wend
'Wend
'SSPBUF = s2m(3)
'datam2s3 = m2s(3)
'Wend
'Wend
Goto main
End
'int_ccp1
On High Interrupt
Save System
PIR1.CCP1IF = 0 'clear IF ADDED
shift_reg = ShiftLeft(shift_reg, 1) 'Shift the bit left one place.
'shift_reg = shift_reg + shift reg would do the same.
LATB = shift_reg 'Write the shift register bits to the port CHANGED &
'Increment index for next servo time value
index = index + 1
If index < 8 Then 'All servos already done?
yled = 1
'WaitMs 100
'No, do next servo
'Set the duration for this output, as a new offset
'from the last compare time.
time_set = time_set + motor_servo(index)
CCPR1L = time_set.LB 'Write the compare time to CCP1 register.
CCPR1H = time_set.HB
yled = 0
Else
'No output needed as the port is already updated.
'output_c(0); 'Turn off all servo bits.
'restarting the sequence.
time_set = time_set + 1500 'add 1.5mS for the next interrupt
'Update CCP
If index > 15 Then '15 * average 1.5mS = 22.5mS, a reasonable frame repeat time
'Set up for a new sequence
index = 0
shift_reg = 1 'Set a bit that will be at port bit 0.
time_now.LB = TMR1L 'Get the timer present count
time_now.HB = TMR1H
time_set = time_now + motor_servo(index) 'And set the first duration
CCPR1L = time_set.LB 'Write the compare time to CCP 1 register.
Endif
Endif
'Toggle yled
Resume
Proc init_spi() 'PIC 18F4431
'4431
TRISC.6 = 1 'CS=1
TRISD.3 = 1 'SCK from MASTER ******INPUT*****
TRISD.1 = 0 'MISO ****** OUTPUT *******
TRISD.2 = 1 'MOSI ****** INPUT *******
'MODE 0,0
SSPSTAT.SMP = 0 'Input data sampled at middle of data output time ** not about clock generation **
SSPSTAT.CKE = 0 '0 Output data changes on clock transition from active to idle ** AS ABOVE **
SSPSTAT.5 = 0 'I2C only
SSPSTAT.4 = 0 'I2C only
SSPSTAT.3 = 0 'I2C only
SSPSTAT.2 = 0 'I2C only
SSPSTAT.1 = 0 'I2C only
SSPCON = 0 'RESET THE CONTROL REGISTER ************ADDED
SSPCON.WCOL = 0 'Collision detect
SSPCON.SSPOV = 0 'Overflow
SSPCON.SSPEN = 1 'Configure SCK,SD0,SDI,/SS ** HAS TO BE 1. To reset or reconfigure SPI mode, clear the SSPEN bit,
'reinitialize the sspcon registers And Then set the SSPEN Bit from the datasheet !!!!!!!!!!!!!!!!
SSPCON.CKP = 1 '1 = Idle state for clock is a high level
SSPCON.SSPM3 = 0 '0100 = SPI Slave mode, Clock = SCK pin, SS pin control enabled,
SSPCON.SSPM2 = 1
SSPCON.SSPM1 = 0 'SLAVE MODE
SSPCON.SSPM0 = 0
End Proc
Hi M,All of the BLDC servo's I have used, I used PWM (transconductance) drive amps for them.
Hi M,BTW, my reference to BLDC servo PWM was in industrial servo's usage, Not R/C versions.
One big difference is the closed loop feedback to the controller, this is required when operating a BLDC motor down to zero RPM in such as CNC arenas, otherwise severe 'cogging' occurs at low RPM if used open loop.Hi M,
I don't suppose there's much difference, apart from size?
C
Hi M,One big difference is the closed loop feedback to the controller, this is required when operating a BLDC motor down to zero RPM in such as CNC arenas, otherwise severe 'cogging' occurs at low RPM if used open loop.
Hi J,Is timer1 used elsewhere than generating servo pulses?
Hi J,Timer1 is on low interrupt so timer2 interrupts it.
Maybe switching priorities helps?
