Hi J,I used only three values because the oscilloscope in the simulator shows only four.
I set the fourth as a 1ms tick, 100us on 900us off in the main loop.
I can look the rest separately.
The shift_reg is set to one in the interrupt, when the first 20ms has passed, so I did not want to wait that.
Waitms value does not matter. The interrupt determines most of the simulation time.
I'm watching the Microcontroller view, and the 8PINs appear to all be the same?
Should I be watching the OScilloscope for accurate readings?
I am trying to load it on a live PIC, and watch on a 'live' Oscilloscope.
I always set the [ Waitms value ] but it looks like it only helps with WAITMS in the main LOOP.
C
There seems to be something wrong, as the SIM is working but 'live' isn't. I'm not programming accurate today, and keep making mistakes
C
