I have a few grey areas when it comes to the design of this power supply.
1) Why have they referenced the op amp supply ground to the positive rail of the power supply output?
2) How does the current sense section work and why haven't they used the traditional differential amplifier configuration to sense the current?
3) Why are the opamps used to sink current rather than directly drive the pass transistors using a darlington or sziklai pair?
4)What is the purpose of anti parallel diodes at the input of the current error amplifier also diode CR6?
https://neurophysics.ucsd.edu/Manua...P361XA 30W Bench Series DC Power Supplies.pdf
I have attached an image of the schematic and a link to the full datasheet.
Thanks,
Jimmy.
https://neurophysics.ucsd.edu/Manua...P361XA 30W Bench Series DC Power Supplies.pdfI have attached an image of the schematic and a link to the full datasheet.
Thanks,
Jimmy.
