how will solve this circut
solve this
  • 5
    Votes: 3 100.0%
  • 5
    Votes: 1 33.3%
  • Total voters
    3
bertus
Joined Apr 5, 2008
23,005
As this looks like homework, I moved it here.
Show us your calculations and we can check them and give hints where you went wrong.
33,171
With just a bit of practice, you should be able to solve this by inspection. Hint -- that diagonal wire drastically reduces the complexity of the circuit.
But in the meantime, do what the question says, which is reduce it one step at a time. You might try first redrawing the circuit in such a way that the all resistors that are electrically connected to the negative side of the source are drawn vertically with one end tied to the bottom node in the picture.
30,807
Reminds me of one of the midterm questions eons ago when I took electronics, it was a cube consisting of 1ohm resistors, and it required the calc of the resistance across two diag corners.
