Picked up a 50 inch Onn Roku TV someone threw out. Tested components on power supply (with multimeter).
Fuse, bridge rectifier and MOSFET are bad.(Bridge rectifier=outer-most legs are shorted in both directions. mosfet=drain&source shorted.)
When it comes to SMPS circuits, my knowledge is limited. I've only worked on one in my life. It was from a Haier TV I used to have. I managed to fix it by replacing the mosfet, fuse and capacitor. (Wasn't positive whether the capacitor was actually bad. But I replaced it anyway.)
I don't know how to word what I'm trying to ask...but, I'll try...
For those of you with more experience working on SMPSs...
Based off your prior experience, are there any other components you suspect could be bad? In terms of the specific components that failed, I mean. (Fuse, bridge rectifier & MOSFET).
I know enough about SMPSs to realize they all work in basically the same way. I imagine, when this specific combo of components fail, there's a pattern to what they take out in the rest of the circuit.
I don't have enough knowledge about how they work to know if there's anything farther down-stream this fault is likely to take out.
Does that make sense?
I asked this question, (just worded differently), on another site. But they closed my post, saying it wasn't a question.
What I'm trying to ask, IS a question. I just don't know how to word it very well.
Hopefully I did a better job explaining it this time.
Oh yeah...apparently, the circuit diagram nor service manual (for this TV) are publicly available. So, the best I can do is post photos of what the board looks like. It's model # is E021m553-f1.
I also noticed the solder between the two diodes (black chips on bottom of board, right beside mosfet) has bridged.
Another area on the bottom of the board has a resistor and capacitor bridged with solder. (Which, I'll fix when I replace the components.) I wish I could post a better photo, that you could zoom in on.
Anyway, can you guys tell me if you've came across power boards with this specific combo of blown components? And whether there were any other components that required replacing? Thanks!!
