OK, if that is accurate then the sensor output is 112.5hz. Why don't you just measure the frequency from the sensor at 1500rpm?but my guess is around
15 liters/minute at 1500 rpm.
SG
Sure why not. Change C to .1uf for relay closure below 50Hz.But I could built the circuit with the LM2907 ic and change values at a later date to suit.??
Change R to 56K.... leave C at .1ufHence the relay must become energized at a minimum of 12 l/min.
The output will drive 50mA, so that’s most 12V relays and quite a lot of buzzers,. As you need the output energised when the speed is lower than the threshold, use the n/c contacts on the relay, saving a resistor and a transistor; but you do need the 16-pin version, with pin 11 biassed to half supply.using the LM2907 speed switch. From the data sheet:
10.2.2 Other Application Circuits This section shows application circuit examples using the LM2907-N and LM2917-N devices. Customers must fully validate and test these circuits before implementing a design based on these examples.
I disagree with the above. Never been a fan of having a relay normally energized and don't see the need for the 16 pin version.use the n/c contacts on the relay, saving a resistor and a transistor; but you do need the 16-pin version, with pin 11 biassed to half supply.
For the 8-pin device, the non-inverting input to the comparator is connected to pin 1, and the inverting input is connected to ground.I disagree with the above. Never been a fan of having a relay normally energized and don't see the need for the 16 pin version.
SG
Are you in the USA?I can get the 8-dip type easy,
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 14 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 13 | |
wire wrap pins | Marketplace | 10 |
