Hi all.
I bought this 1500W 30A1800W 40A DC-DC Boost Converter Step Up Power Supply Module 10-60V to 12-90V adjustable voltage charger [boost]
https://www.aliexpress.com/item/400...o.order_list.order_list_main.5.5d091802jFZ5Gs
and a 48v-1000w switch power supply [power], and wire them up, the power measured good output 48V.
when connected boost TO power, power can't start up, and boost's under voltage indicator light flashing, I did few turns adjust on Input low cell protective regulation pot, turn on again heard two explosion and saw sparks in area A and B, and now power is on, boost output only 48v. what can be?
1. three fuse measured good;
2. can be one of the four capacitor blow out?
Adam
POWER:
BOOST:
area A & B:
Adam
POWER:
BOOST:
area A & B:
