does this mean you wont be helping me anymore with my project?Well, good luck with your project.
I have buffers at the output of the mux.If your professor won't allow you to use opamps as buffers on the inputs of the 4051, see if you can use them on the outputs.
You need to convert the high impedance inputs to low impedance as quickly as possible, or it's just not going to work well.
It will do the processing, rectifying and outputting while inputting. It doesn't take a chunk, process it, output it, then grab another chunk. It happens on the fly.i mean, before the amplifier can process the signal, rectify and produce an output, the input signal changes... Can this happen??
Yes... I know, just wanted 2 show my prof, that using buffered mux is a costly affairThat is the inverting input to the output amplifier. If you connected it to the output of the amplifier, it would be a buffer amp/voltage follower.
Do you see how much those IC's cost? Around $7 USD each.![]()
Yes.... I changed the amps now...They have a 250MHz bandwidth, which is nice if you're doing video processing, but overkill to the maximum for what you are doing. Your power usage would increase quite a bit. That is why I suggested the low power rail-to-rail opamps that I did.
Yea... will try tat out...So, does it work properly when each mux input is buffered like I suggested a number of posts back?
Did you try the "fallback" idea, which was putting some 10nF caps on the inputs of the mux, and buffer amps on the outputs of the mux? This would tend to reduce the signal from the foil sensors quite a bit, and if you had any cross-conduction in the mux during switching, it wouldn't be long before you had no signal again.
Faraday Cage? .. but isnt it like pretty big? Moreover, I cannot have the room covered. It is meant to be used for old people... No other method? like having capacitors placed at particular distances? I have a ground plane below the aluminum foil sensors... Also, the sensor size is only 6"x6" and distance between two sensors is 1 feet... so, interference is somewhat less....Construct a large Faraday cage.
I'm tempted to suggest fill the room with saltwater, but that would likely cause damage to property, so I won't.
Actually, probably the cheapest thing to do is to keep the relative humidity around 60% to 70% If it's much higher than that, you will likely have mold problems. If it's a lot lower, you will have a lot of static electricity.
Unless you construct a Faraday cage (which would be very expensive) you won't be able to keep RFI out.
PCB design: Lots of info on this link: http://www.smps.us/pcb-design.html
I am sensing if a person is stepping on the sensors or not... The system works pretty well for the previous 2 prototypes in which I had 21 sensors and 4 sensors respectively....I think your sensors and wires will pickup all kinds of interference plus a lot of static electricity.
What do you expect to sense?
Yes, exactly.... that's what my research is all about...OK, but you are just looking at static voltage levels.
When someone steps on a sensor, the charge would momentarily decrease as the dielectric is squeezed together.
You're not using it as a resonant tank; you're using it as a momentary change in voltage sensor.
