Hello,The inputs or output of the analog multiplexers must be biased at a DC voltage that is within their supply voltage range, preferably at half the supply voltage.
I changed the supply voltage of the mux to 3.0 V now, and the micro-controller is operating at 5v, so essentially, the output voltage at the micro-controller should be 5V.
however, I am unable to get 5V at one of the ports of the micro-controller (specifically the port pin which is connected to select lines of 4:1 mux. this happens mostly as I am continuously scanning the input lines, so the uC code follows 00,01,10,11 pattern.. truth table of the 4:1 mux... hence, the avg voltage I observe is approx 3.8 V)
Is there any better way to get this done?
Thanks in advance
