How to use a PNP with a 12v battery?
James55
Joined May 29, 2016
39
Hi all.
Please forgive me if this is a simple answer but I am still learning about transistors.
My question is, "What would be a simple way to create a PNP Base/Emitter voltage of 5 volts, whilst using a 12 volt battery?"
With 12v across an NPN, an LM7805 could do the job, but I was wondering how about when a PNP Collector/Emitter voltage is 12v?
James
wayneh
Joined Sep 9, 2010
18,164
Hi all.
James
There are many possibilities but we’d need more info to make a choice. Let’s start with why you need that voltage. The transistor will turn on at 11.3V and you’ll need to limit the base current to avoid burning up the transistor.
A schematic would save a lot of questions.
k7elp60
Joined Nov 4, 2008
562
Hi all.
James
I am not sure what you mean. In a normal configuration of a transistor in the conducting mode the base to emitter voltage is very close to 0.6V. The polarity depends on which type in use NPN or PNP.
ScottWang
Joined Aug 23, 2012
7,505
You will need a 6.2V zener, and you should in series with the PNP as below:
Vin E(P) → C(P) Vout
Vin B(N) → (-)6.2V Zd(+) → C(P) Vout
0.7V = Vbe
Vo = 12V - (0.7V+6.2V) = 5.1V
The output voltage of this kind of simple PNP circuit will be have a little changing when the draw current of load is changing.
James55
Joined May 29, 2016
39
Thanks for the replies.
It was more just a theoretical question, however I can't seem to upload a schematic.
If you imagine a 12 volt, 3A fan and perhaps a MJ11015 transistor (with base resistor), which is controlled by a manual switch coming from the 12 volt battery, then you will see that the circuit is missing a component to reduce/limit the voltage, as there is a 5 volt maximum across the emitter/base junction.
I had been wondering about a zener.
ScottWang
Joined Aug 23, 2012
7,505
Have you got any message?
You can compress it as .zip file and upload it, I can decompress(unzip) it to the original circuit.
James55
Joined May 29, 2016
39
Can't seem to upload anything.
The window appears with the 'browse' option, but with only a 'cancel' button... ?
ScottWang
Joined Aug 23, 2012
7,505
Did you see the button shown as "Upload a File" and it is at the right bottom of the message box.
Or you want to use the FireFox to upload the file.
James55
Joined May 29, 2016
39
Yes. When I select the 'Upload a File', a box appears and I can browse to my selected archive.
When selected, it shows 3 movings bars in the corner of the window however nothing uploads.
Have tried different formats and various files.
It is not so important. I believe the question was answered with the Zener option.
Many thanks.
wayneh
Joined Sep 9, 2010
18,164
You don't need anything as fancy as a zener, a simple current-limiting resistor will do. The base-emitter resistance is very low once you overcome the two diode-drops of ~0.6V each (two because your transistor is a darlington). With no resistor and unlimited available current, >5V applied to the base would indeed roast the transistor due to excessive base-emitter current. But suppose you place a 100Ω resistor in series with the base, and connect the other end of that resistor to ground. Now the maximum current that could flow is limited to (12 - 1.2)/100 = 0.108A. Almost all the voltage drop occurs across the resistor and the base remains at a safe 1.2V and a current well below the 1A rating.
So just put your manual switch and a resistor in series between the base and ground, and you'll have manual control over the transistor. Use a resistor that allows about 1% of the load requirement to flow on base-emitter. That will ensure that the transistor is turned fully on.
LesJones
Joined Jan 8, 2017
4,543
This is what you expect to see when you click on "Browse"
You would then click on the file you want to upload.
Is this the configuration you are talking about to use a PNP transistor as a switch ?
If so the base emitter junction is never reverse biased. If you are using a normal transistor (Not a darlington.) then you would choose R1 to give a base current about one tenth of the load current. R2 is not really required it just reduces any leakage current. I would choose about 10 times the value of R1. It was more important in the days of germanium transistors as they had higher leakage currents than silicon transistors.
Les.
ScottWang
Joined Aug 23, 2012
7,505
Les.
What he want is from 12V to 5V.
wayneh
Joined Sep 9, 2010
18,164
This is exactly what I was envisioning in my post #16. Nothing more than what you have drawn is needed to protect the base of the transistor from the 5V max base-emitter voltage.
