How to use a PNP with a 12v battery?
LesJones
Joined Jan 8, 2017
4,544
You could be right. Some of the TS's posts do seem to suggest that but I was working from his description in post #7. This is one of those posts where working out what the question is is the difficult part.
Les.
James55
Joined May 29, 2016
39
This is what you expect to see when you click on "Browse"
You would then click on the file you want to upload.
This IS what I see, it's just that nothing uploads.
Is this the configuration you are talking about to use a PNP transistor as a switch ?
Yes, this is the configuration I was talking about.
If so the base emitter junction is never reverse biased. If you are using a normal transistor (Not a darlington.) then you would choose R1 to give a base current about one tenth of the load current. R2 is not really required it just reduces any leakage current. I would choose about 10 times the value of R1. It was more important in the days of germanium transistors as they had higher leakage currents than silicon transistors.
Les.
The MJ11015 transistor I mentioned is a Darlington PNP with an Ic/Ib of 100. It wasn't the base current, nor resistor which I was wondering about, it was how to ensure that there wasn't 12 volts across the emitter/base junction, when the datasheet states a maximum of 5 volts?
ian field
Joined Oct 27, 2012
6,536
Hi all.
Please forgive me if this is a simple answer but I am still learning about transistors.
My question is, "What would be a simple way to create a PNP Base/Emitter voltage of 5 volts, whilst using a 12 volt battery?"
With 12v across an NPN, an LM7805 could do the job, but I was wondering how about when a PNP Collector/Emitter voltage is 12v?
James
The BE reverse voltage is often as low as 5V, and its usually best avoided. The BE forward volt drop is around 0.7V for a silicon type. The old germainium types were almost immune to the reverse VE vulnerability, but many reasons for not using them - including rare and expensive.
Hard to work out what you're trying to do - but you might fond a P-channel MOSFET less constraining.
wayneh
Joined Sep 9, 2010
18,184
That's what I thought you might be asking. Answered and diagrammed above. No worries.
wayneh
Joined Sep 9, 2010
18,184
For a 3A fan? You need about 30mA of base current. I'm a little confused what the voltage applied to the base will be. Whatever that is, use Ohm's law ∆V = I • R. In your scenario, ∆V = emitter-base and we already know we want the current I to be 0.03A. Just solve for R. You can probably get away with a bit larger value, no need to go lower.
James55
Joined May 29, 2016
39
Apologies for being slow, I misunderstood that you were talking about the resistor value.
I thought there was some new, funky type of resistor that automatically only allowed 1% of the load value to pass. Totally missed the transistor gain of 100. Doh! :rolleyes:
ScottWang
Joined Aug 23, 2012
7,509
When the PNP is a Darlington pair then the Zener diode should be change from 6.2V to 5.6V and you should in series with the PNP as below:
Vin E(P) → C(P) Vout (Darlington pair)
Vin B(N) → (-)5.6V Zd(+) → C(P) Vout
Vb = 0.7V
Vout = 12V - (0.7V+0.7V+5.6V) = 12V - 7V = 5.0V
You need to connected a 200Ω (false load) resistor from Vout to ground when you measure the Vout voltage, the output voltage of this kind of simple PNP circuit will be have a little changing when the draw current of load is changing.
The 200 (false load) resistor is used to provides a 5mA Minimux current for the Zener diode when you to do the test.
The below is the simulation and the original is used 5.6V zener diode, but I can't find it in the libraries, so I used 6.2V to replace it, something in the simulation can't be the same with the real world, when the Load is drawing more current then the output voltage will be a little different, W = 7V*3A = 21W and it was waste on the darlington pair for nothing.
James55
Joined May 29, 2016
39
Hi Scott.
Thanks for the more detailed explanation. I wasn't completely sure what you had meant before. Unfortunately I don't have a program to open your attachment.
I'll set up a test circuit when I get a minute in a while.
It would be nice to have some voltage regulation seeing how a 12 volt battery is rarely actually 12 volts.
Ramussons
Joined May 3, 2013
1,572
Hi all.
James
A LM7905 would do the job just like LM7805.
