How to use a drop in voltage to trigger a switch?
PulseLED
Joined Jan 24, 2014
27
The problem, I want something to turn on when a drop in voltage is detected.
I know this can be done with a relay, but its not very versatile, unresponsive and slow.
I'm looking for the opposite of a transistor I guess. Something that will detect a slight drop in current, then allow more current through another circuit. What is the simplest way to accomplish this?
#12
Anti-transistors haven't been invented. We just wire up the regular kind to work the logic backwards.
MikeML
5,444
Need more specifics:
Rate of change of voltage?
Magnitude of the voltage before and after the drop?
What happens when the voltage goes back up?
PulseLED
Joined Jan 24, 2014
27
The specifics are not known,I was more after a few examples of how this is accomplished so that I can research it and test myself. Voltage range is about 9v DC but I'm unsure of the actual trigger voltage drop etc.
How are they wired up?
A little more on the intention/circuit/devices are required, in some cases a simple comparitor will do it, LM311 etc.
Is there a simple example of this?
30,814
I have used the LM311 to detect a change in a 240vdc mobile application.
The output will turn on/off as the set point is exceeded or below.
TheButtonThief
Joined Feb 26, 2011
237
Either use a PNP transistor or still use a NPN transistor but flip over your voltage divider.
You could also take a look at schmitt triggers or op-amps as comparators if you want to learn something a little more complex.
