how to turn ir2110
Papabravo
Joined Feb 24, 2006
22,096
hi i'm trying to turn on the high side (ir2110)
the low side work well but the high side show's like dc
what is my problem
If I had to guess, it would be that you do not understand the requirements for driving a high side switch. In this context it refres to a switch that is not referenced to ground potential. One side of the switch (usually the source terminal) is referenced to some voltage above ground. The gate signal must be 10-15 volts above that potential. If you do not have a power supply voltage required by the gate you must synthesize it. One way of doing that is using a bootstrap capacitor and an oscillator to create a voltage that is higher than any avalable power supply. As has already been mentioned you need to keep the oscillator going; if it stops the bootstrap voltage will decay to a lower value and fail to operate the switch.
cukcuk
Joined Sep 13, 2023
10
안녕하세요. 해당 소자를 처음 사용하는 새내기인데, 어떻게 동작시켰는지 회로 사진을 보내주실 수 있으신지 여쭤보고 싶습니다. 감사합니다
Moderation translate, please use English text
hello. This is my first time using this device, so I would like to ask if you could send me a picture of the circuit and how it worked. thank you
MaxHeadRoom
Joined Jul 18, 2013
30,756
See the link in #3 post.
27,880
what is my problem
Like I have suggested to other, get hold of the application notes, and then read them. The app notes are the most accurate source of information because the manufacturer provides them so that users know how to apply the product. This is almost without exception in the electronic components industry..
MaxHeadRoom
Joined Jul 18, 2013
30,756
How do you intend using the device? H-Bridge etc? Have you attempted to implemented it yet?
The OP appeared to have an issue with the bootstrap circuit. !
cukcuk
Joined Sep 13, 2023
10
Thnaks for your help! I am trying to boost 0-5V pwm signal from arduino. I then read the article you mentioned right after your reply and it helps me a lot to understand the gate driver. Thank you so much
BobTPH
Joined Jun 5, 2013
11,594
Don’t know how you plan do that with a high side gate driver.
Assuming you have a higher voltage power source, all you need is an N channel logic level MOSFET used as a low side switch.
cukcuk
Joined Sep 13, 2023
10
Boost it to what voltage?
How much current do you need to draw from the boosted voltage?
What power supplies do you have for your boost circuit?
Making 0-5V to over 12, I supplied 12V to VCC then connected the pwm to Low input pin 12 and It worked today as I followed this.
BobTPH
Joined Jun 5, 2013
11,594
So you are using a MOSFET gate driver as a MOSFET. Sure it will work, since that is all the low side switch is. But why?
cukcuk
Joined Sep 13, 2023
10
I do not have a specific reason but just wanted to handle various size of PWM during school experiment and I found the term of a gate driver
shortbus
Joined Sep 30, 2009
10,049
Seeing that schematic gave me a kind of dumb idea. Could you use one gate driver using the low side to do away with the bootstrap on another driver for the high side? Just kind of thinking out loud and it may not work.
MaxHeadRoom
Joined Jul 18, 2013
30,756
Not sure of your meaning, is to just use the bottom driver only?
Any time you use a high side driver, there has to be a path to power common.
Alec_t
Joined Sep 17, 2013
15,136
You could use the low-side driver to switch current through an inductor, thereby making a boost converter, then use the boosted voltage to drive a high-side FET gate.
