how to test mosfets on board with LCR-T7 ?
disturbed123
Joined Jun 11, 2020
127
hi there. let say that we have faulty computer motherboard and i want to fix it. i see in clips in YT that they are checking on board.
Which pins to check and what to expect for faulty component ?
thanks in advance
anybody repairing motherboards to tell a good tester put on SLOT to gives error code?
meth
Joined May 21, 2016
328
I dont think you can make conclusive test while the component is on-board, especially no if you want to use the tester to check it's gain, but if you use the measurement device in diode mode, and you have short circuits all over the FETs that is a good indicator that is broken.
Start motherboard repair with a digital multimeter. Check power rails, including 12V, 5V, and 3.3V. Also check connectors, voltage regulators, and visible component damage. Measure resistance only when power is disconnected.
disturbed123
Joined Jun 11, 2020
127
hi there.
I know that for a reliable test I should remove the component from the board, but I’m just looking at what others in the field do.
Between which pins should I test a MOSFET, and what should I expect to see (and what setting should the multimeter be on)? I’m referring to D2PAK surface-mount packages.
Sorry if my questions are a bit confusing; I’m using Google Translate today.
meth
Joined May 21, 2016
328
You can use the multimeter in diode mode and treat the mosfet/transistor as two diodes, for example if you have NPN transistor (P-base, N-collector and emmiter), you should get a diode reading when you have your positive probe on the P and negative on the N's, just like a diode would measure. In the opposite case (positive on N and negative on P) you should read a somewhat open circuit. Same analogy for PNP transistor or N-channel mosfet.
But still if you test this while components are soldered, the other parts on the PCB might affect the measurement.
Generally, if you have short circuits all over the MOSFET it is probably dead. That should be detectable immediately.
MisterBill2
Joined Jan 23, 2018
28,603
Checking the resistance of an in circuit device in both directions is useful, if the resistance is the same low value in both directions then the device is certainly suspect. IF one pin can be isolated and the resistance in both directions remains the same, usually the fault is verified. BUT if external components are connected , maybe not!!
disturbed123
Joined Jun 11, 2020
127
i am learning now. i have one pc motherboard and if i think right the most of the electrolytic capacitos are failed. do you think this can be true ?! i am using check on the board with digital multimeter - charging the C with + on + and after that cross and should hear a beep.
thanks in advance
the motherboard has no socket for CPU, its on board.
disturbed123
Joined Jun 11, 2020
127
What makes you think that any part on the motherboard has failed??
I power the motherboard with healthy power supply unit, put memtest86 testeD RAM and the CMOS battery has 3 volts.
MisterBill2
Joined Jan 23, 2018
28,603
OK, that is an interesting test process. MANY portions of a current PC motherboard would have 3 volts instead of five volts.
It is obvious to me that I do not clearly understand the test logic you are using . MOST PC RAM batteries only have three volts. THAT is what the small attached battery provides when the PC is not powered. With the MB powered an on-board regulator supplies that voltage.
I do not believe that a PC motherboard is that simple to test. NOT AT ALL!!
disturbed123
Joined Jun 11, 2020
127
is there someone who wants to give me his/her facebook or some other contact information for me to ask some questions.
I search a lot of methods for learn the things and won`t quit.
I wrote in bulgarian facebook groups that i want someone to teach me some things but no one wants.
Some of my colleagues aren't particularly polite, and, honestly, they get on my nerves.
if needed i can pay.
thanks in advance
how much is the new motherboard and how much you are willing to pay? i am guessing you are not interested in repairing just one board.
there are repair channels dedicated to things like this with valuable tips.
most of repairs boil down to finding/fixing short circuits. DMM can take you only so far, more tools are needed (in addition to instruments, thermal camera, ultrasonic cleaner, etc.)
did you consider talking to AI? they too are getting better pretty fast...
