- Joined Jan 23, 2018
- 28,227
If the refrigerator is indeed an LG brand unit, then it probably is a failed fan motor.
But one simple check that will reveal if it is instead a failed defrost system, which will result in ice blocking the path for cold air to the refrigerator, is to disconnect the power to the unit and let it defrost, empty, with the doors open, for 24 hours. If that solves the problem then you have a failed defrost system. although the fan motor may also be failed. Defrost system failures can be interesting indeed.
