How to switch the ac phase not the neutral
Dodgydave
Joined Jun 22, 2012
11,395
Sounds like a 3 input quiz buzzer, whoever switches on first starts the water pump.
Three relays with interlock contacts,
Then use that relay/contactor to supply the pump from that phase,
MaxHeadRoom
Joined Jul 18, 2013
30,726
You need three contactors feeding the motor from each phase, the other two are interlocked off when more than one switch is activated.
Max.
BR-549
Joined Sep 22, 2013
4,928
Which switch is on, is not related to who uses the water. I could live in your apartment, and never turn that switch on.
recklessrog
Joined May 23, 2013
985
Relays slower? They are faster than your motor will run up to speed! Don't rule them out because they are mechanical, you should really use a proper motor contactor with over current sensing, then control that as I previously described. it is not always best to try and re-invent the wheel.
