How to switch ground alternatively to IC pins using momentary spst switch
patrick398
Joined Sep 16, 2019
24
No, I don't.
If I were to design a guitar pedal today I would look at a digital design.
DSPs today are compact and low powered enough to fit into a hearing aid.
Ok well before i venture down another rabbit hole of things i barely understand i may as well take this current approach to it's conclusion.
I think i understand how to use the 4013 to switch the DG403 now, what i'm still confused about is what connects to Pin 12
35,179
Pin-12 of the DG403 is the digital logic supply VL.
Connect this to the same digital logic supply rail of the CD4013, pin-14, VDD.
