How to switch ground alternatively to IC pins using momentary spst switch
patrick398
Joined Sep 16, 2019
24
Remember to also move the 100 ohm resistor to the transistor emitter.
This does seem to slow down the changing of the flip flop state; i can see the ramp in the LED, it's slower on the turning off than the turning on. That said, it did nothing for reducing clicks so i guess that must be coming from elsewhere.
I bought a DG403 chip to try out, to see if i have better results with a dedicated switching IC. From what i can tell it is suitable for my needs but there are many things in the datesheet i don't understand so perhaps i'm wrong. http://www.vishay.com/docs/70049/dg401.pdf
patrick398
Joined Sep 16, 2019
24
Like what?
Well i understand a few things from reading i've been doing about switching, like importance of low Ron and flatness of resistance across frequency spectrum. I've also read that quicker switching times reduce switching noise which i find counter intuitive. Also make before break switching helps reduce click and pops.
This IC seems to require a bipolar supply so i'm thinking i can use 4.5v vref from a 9v unipolar supply. This should hopefully leave me enough headroom.
Pin 12 is VL which i guess stands for voltage logic? Is that regulated 5v?
On the datesheet example circuit it says TTL goes to pin 15 and 10...TTL is some kind of transistor flip flop?
38,813
The switched signal needs to be between the plus and minus supply rails.
So if you use a single supply and it's a ground based AC signal, then you have to offset the signal to 1/2 the supply voltage (you could use capacitor coupling with a resistive divider offset to do that).
If you use standard logic levels for control, then that would be 5V. but it can be equal to the supply voltage if the logic control signal is a least 1/2 that voltage (see the Input Switching Threshold vs. Logic Supply Voltage graph).
It refers to the logic voltage levels.
TTL (transistor transistor logic) is an old logic IC family with 0.8V maximum for the low logic level and 2.4V minimum for the high logic level using a 5V supply.
patrick398
Joined Sep 16, 2019
24
Thanks again for the help with this!
So biasing all the signal lines to 4.5v would require 8 resistors and 4 DC blocking caps. Alternatively i could use a voltage inverter to give me -9v and run the signals normally? Just thinking about keeping this circuit as small as possible.
Also the TTL would be a separate IC?, am i not able to do this switching with trannies?
djsfantasi
Joined Apr 11, 2010
9,237
TTL is not a component. It is a specification for a standard set of voltage levels for logic. So in your case, pins 10 & 15 are expecting an input which confirms to the TTL standard.
patrick398
Joined Sep 16, 2019
24
So i'm unsure what kind of circuit to use to control the switch. I don't think i can use the 4013 because it output is too high. Sorry for all the questions, i've not really worked with logic stuff before
djsfantasi
Joined Apr 11, 2010
9,237
A CD4013 is a Dual D type CMOS flip flop. A similar chip that conforms to the TTL standard is a 7474. Google “7474 IC” for more information. Since it’s TTL, it’s output will be compatible with your board.
patrick398
Joined Sep 16, 2019
24
Thanks a lot, i'll look into that :)
After reading something about switching with 4066 it mentioned using 40106 as the logic control. Would that be possible with this DG403? Something like this (sorry for the crude drawing):
patrick398
Joined Sep 16, 2019
24
What's wrong with a CMOS chip?
TTL levels are minimum levels.
A 0V low and a 5V high will work just fine.
Ah i think i misunderstood, i thought it was being implied that cmos was not compatible with this chip. I have the 4013 still set up on the breadboard, i could use one of the outputs and tie it to pin 10 and 15 and use 0v and 5v as the logic if i ran the 4013 off a 5v regulator? Or i could use 0v and 9v if 'the logic control signal is a least 1/2 that voltage (see the Input Switching Threshold vs. Logic Supply Voltage graph).'
I'm not sure i understand that last sentence...is that the voltage on pin 12 of the DG403?
Sorry i'm well out of my comfort zone here ha
patrick398
Joined Sep 16, 2019
24
Have you considered using CD4016 or CD4066 to switch your analog signals?
Yes this is fairly common method in effect pedal switching, from what i have read it still suffers from issues with switch noise. My hope in trying to DG403 is that it implements a few things to reduce or remove this such as break before make switching
35,178
I suspect that switch-over pops and clicks have nothing to do with the switch but how you transition from one level to another.
Sounds like a simple solution for a low cost DSP MCU.
patrick398
Joined Sep 16, 2019
24
Yes but i have found in experiments with other methods that even eliminating DC offset on the signal lines seems to leave some switch noise. I was hoping that some internal trickery of a switching IC might eliminate this. Also, if using this the DG403 i have to bias all the signal lines to 4.5v they should all be at the same level, meaning no DC offset and no pop?
35,178
Depends.
In order to eliminate the pops you have to switch at the zero-crossing.
