How to start learn pid analog.
Sensacell
Joined Jun 19, 2012
3,789
Build a simple circuit with an opamp- with only "P" - proportional control.
Get the feel for how it works, then add circuits for the I and D as you learn more.
You need a "plant" - something to control that has an input and an output.
A temp sensor glued to a power resistor is a really simple "plant" you can build- try to control the temperature.
38,844
......A temp sensor glued to a power resistor is a really simple "plant" you can build- try to control the temperature.
Yes, a large power resistor with significant thermal mass makes an interesting challenge to optimize the control loop parameters such that the temperature will rapidly reach the control temperature without overshoot or hunting (oscillation).
A quad op amp, such as an LM324 can be used to easily generate the proportional, differential, and integral functions.
The required time-constants for the integral and differential functions will be in the ms to seconds region.
Should be a good learning experience. :)
JohnInTX
Joined Jun 26, 2012
4,787
hello,
i want to learn pid analog circuit from where should i start?
I want to say I very much appreciate the good replies from our members to your question. They add to the forum and I frequently learn from them as well.
But I have to ask again, why can't you search for some of this yourself? Pasting your exact question text into Google got lots of good hits on this very subject. Our members are talented and generous but it is unreasonable to continue to expect that they will continue to do your work for you without complaint. Your continued participation at AAC will depend on you taking some initiative and finding things out for yourself before dropping random questions here.
It is as simple as this.
WBahn
Joined Mar 31, 2012
33,236
Another good plant, which is very similar, is a temp sensor glued to a 60 W incandescent light bulb. It gives you a nice visual indication of whether your system is operating in the ballpark (though of course you won't see high frequency oscillations).
embedded29
Joined Apr 8, 2017
72
where is circuit?
This is a really cool idea, I'm going to try this next. Thanks!
Travm
Joined Aug 16, 2016
363
hello,
Build one of these.
This image the board is missing the opamp, the Pot, and the 2-digit 7-segment display i have for feedback.
What this does is adjust the brightness of the 3-led's by controlling the PWM of the MCU output through an RC-filter, the op-amp gets its feedback from a low ohm (i forget just now, maybe you can read the blue resistor in the image) current feedback resistor, amps it up, feeds it to the MCU, which then determines how much current the LED's are consuming, then the MCU does whatever it wants with it.
The POT is how you tell the MCU how much current you want the LED's consuming via the MCU Analog to digital converter.
I'll post a more up to date pic later tonight from home.
I would gladly sell you one of these boards and component sets at cost and share my circuits with you if you promise to share you findings with me. I had to buy in qty of 10 for the boards, and the components (most of them) were almost the same cost for 10 as they were 1.
GopherT
Joined Nov 23, 2012
8,009
Build one of these.
How does this meet the Thread Starter's goal of Analog PID? And that's Analog PID.
GopherT
Joined Nov 23, 2012
8,009
Undermined by Google!
John's lmgtfy.com link brings up google results that point him to this thread! Top result!
Travm
Joined Aug 16, 2016
363
perhaps i misunderstand the semantics. Using a microcontroller to control an analog load with software PID in my mind would be Analog PID, but I think I get where I went wrong on that.
Analog PID would refer to using discrete components to create a PID controller, without an MCU or digital software.
Had to think that mess through. appreciate the clarity.
GopherT
Joined Nov 23, 2012
8,009
Analog PID has gone the way of flying governors but they are still good for teaching /learning experiences. Cheers!
