How to select a NTC(Thermistor) ?
sneha.123
Joined Jun 11, 2014
4
Hello
I Have a design that needs to have very low resistance 0.2 ohms at -25 deg.Can i get help on how to select the same.
R!f@@
Joined Apr 2, 2009
10,004
Hello sneha. Welcome.
I am sorry I haven't yet seen one but may be other members had. Give it some time for others to respond.
sneha.123
Joined Jun 11, 2014
4
It is used to to see when the cooling ability of the system breaks down.By knowing the power the system can withstand the resistance is calculated to 0.2ohms.I need to select the NTC accordingly.
pwdixon
Joined Oct 11, 2012
488
Why must the thermistor be such a low value? Normally in most measurement scenarios people want to have a large thermistor value to reduce self heating and save power on the measurement system itself.
joeyd999
Joined Jun 6, 2011
6,311
Ummm...not always. Driven with a constant current, lower R results in proportionally less power, as P=IR.
OTH, I am not sure the OP understands what he really needs. 0.2 ohms at -25C to seems quite unusual.
