How to Select an Fiber Optic Photoelectric Sensor with Matching Specifications
Tred001
Joined Aug 18, 2024
Hi everyone,
This sensor shown below HPX-A18 broke down and I am searching for a replacement. Unfortunately to find the same one is very difficult and if possible probably it will be a used one. I want to find a similar product and replace it. Here is the image which shows if it's normally open or normally closed:
That is one of my questions is it normally open or closed? The voltage spec is clear as well. The connection is basically by soldering cabels. I managed to find some more information but not sure if it's the same one.
I am not sure if it's the same because mine is HPX-A18 and here there is no mention of 18 only 1. But it looks almost the same.
So please let me know which parameters and what type of replacement model should I be looking for.
Any help would be highly appreciated.
