MisterBill2
- Joined Jan 23, 2018
- 28,049
In some parts of the world, in some groups, they will steal dirty socks and your half eaten candy bar. Most of us have not seen that part of the world. For which they should certainly be grateful!!
Certainly, and they use high tech devices worthy of Q to crack electronic locks. (Q from James Bond, not Q anon)In some parts of the world, in some groups, they will steal dirty socks and your half eaten candy bar. Most of us have not seen that part of the world. For which they should certainly be grateful!!
I lived in that part of the world in my youth. I've seen criminals bash the head of some poor guy in with a rock for a stick of mystery meat, nobody on the streets has or ever will have EMP weapons and the local law enforcement has guns they love to use.In some parts of the world, in some groups, they will steal dirty socks and your half eaten candy bar. Most of us have not seen that part of the world. For which they should certainly be grateful!!
I do understand that mechanical part of the lock is the one that can get compromised first. I mean there is a device called "jaws of life" which is a hydraulic cutter that can cut through car doors like butter.ChatGPT is a useless source for this sort of information. It's just repeating paranoid fantasies about EMP attacks and weapons. This is how you open a high security door.
No need for EMP, just a couple of jumper clips and a power supply.
I do understand the need for security. A simple mechanical safe combination lockbox is a lot simpler and is also EMP proof. Most electronic lock designs are defeated on the mechanical side because that's what really keeps the lock, locked.
https://www.kcolefas.com/en/insights/safe-lock
Thanks for getting back to me. I need to avoid mechanical keys, passwords etc. entering a lock combination cannot be safe when its being done in public. you just dont know who is watching you especially with smartphones with high speed cameras with high frame rates and 20x zoom.There are, and have been for many long years, locks that snap closed and locked when a door is shut, totally independent of any external action. Some of those locks are adequately immune to external manipulation.
In addition, there are electrical and electronic combination locks that provide an alarm signal at any incorrect attempt to unlock.
And another device that is forbidden on this site is the "Black Max" protection system, normally used to secure a motor vehicle against unwanted access. That device has been demonstrated to be effective every time. It IS RATHER LETHAL!
I appreciate you looking into the detailed working of the circuit. This is truly helpful. I will explain the basics here. I was hoping that some electrical engineer would look at the LTSpice schematics (.asc) files that I have uploaded on my google drive (link in the original post) and then just have the circuit reviewed and give out pointers on how to keep it safe against the attacks that I have listed but let me still give out as much details as I can here.1. You keep using the word "trigger" and it is not clear what you mean. Is this a on/off power switch, a pushbutton switch, an external signal coming through a opto-coupler, or something else? Please explain in physical and electrical detail how the circuit is started.
2. How are you getting a mechanical clock to "trigger" an electronic circuit?
3. Do you mean that the circuit releases the solenoid after the *lid* is opened? If so, how does the circuit sense that the lid is open?
4. What is the power source for the system? Where is it located? ALSO - what state should the system be in when power is interrupted and then re-applied? Still waiting for a timing diagram that shows how the system states and control signal states interact.
5.
If the circuit can be controlled by an external electric signal, what is this signal and where does this signal come from?
Where are you located?
If you have something so valuable that someone is going to mount a hight-tech attack to steal it, why not just sell it for $1M and then find a home?
Thank you for sticking out for me and offering me these great design ideas. Your proposed design is quite similar to my first design where I used a 555 as latch and had it on by default when system started and then I had a RC for a delay afterwards.Just for fun, here is a first pass at a simplified design concept. No oscillator, no divider or shifter, just 3/4 of a quad NAND gate package. The operation should be the same as in the post #1 schematics. By using logic gates as circuit elements, three steering diodes and resistors were eliminated. Also, everything runs on battery voltage, eliminating the U5 voltage regulator and its support components.
Key to this design is the use of gates that have Schmitt trigger input stages, This lets them operate with input signals that have very slow rise and fall times, such as an R-C circuit with a 1 minute fall time.
U1A and U1B form the timer control flipflop. C1 assures that the circuit powers up in the "reset" state. In this state, D1 clamps the voltage across C2 to a high voltage near Vbatt.
R2-C2 is the main 40-second timer. Pressing the Manual switch Sets the flipflop. The U1B output (pin 4) goes low, and C2 begins charging "down" through R2. After approx. 40 seconds the lower end of C2 goes below the U1C input threshold.
U1C acts as an inverted-input OR gate - if either input goes low, the output goes high. This turns on Q1 and pulls the lower side of the load to GND. Pressing the Alarm switch pulls pin 8 low and turns on the output. This overrides the timer control signal at pin 9.
As in the original schematic, U4 is an optocoupler for a signal that turns off the output no matter what is going on anywhere else in the circuit. This overrides both the timer and the Alarm input by pulling the Q1 gate to GND, turning it off. In case the U1C output (pin 10) is high, R5 protects the gate's output from a virtual short circuit to GND through U4.
Please review this to see if the operation is correct. I'll add three filter capacitors to protect the gate inputs and Q1 from EMI. Note that some of the part numbers are different from your schematic; these are not recommended changes, I just used similar parts that already are in my design libraries. Click on the schematic for a larger image.
It is a re-arrangement of your idea in schematics 2 and 3.This is a great idea. this prevents the latch from being on in its default state when system is powered on.
mechanical locks can be easier to bypass than electro-mechanical locks. for starters, with my design there is no key or passwords that be looked at with some smartphone at a few meters away with 20x zoom settings. its some evident from "mr lock smith" channel on youtube (https://www.youtube.com/channel/UCjokUyTM9hMhTBjqgbuVtCA) that Neodymium magnets can be used to open most lockers. from him I got the idea of placing the lock right at the center of the steel box so its equidistant from top , bottom, left and right sides of the steel container hence minimizing the effects of a strong super magnet.I am not sure why you need so much autonomy for the locking action, but it seems that using a limit switch (mechanical or optical) such that closing the lid latches the box (possibly with a warning buzzer and a short delay) is more useful being closed loop as opposed to counting on a timer that has no idea if the box is even closed.
I would also question why a thief wouldn’t just steal the box. I would include a tamper alarm so if the box is moved or otherwise molested after locking it would alert you so you don‘t just sleep through it.
One final thing I would do is to use something like an IMU so I could tap a code on the box and open it if I needed access and it had been locked. Having a phone and a laptop isn’t going to be very useful if then you need them, they are locked in a box you can’t open.
As another member pointed out, this whole thing seems like such overkill that I can’t help but wonder if you are doing it to avoid doing something else, more effective, to improve your situation. There is an undercurrent of exaggerated importance which seems to be driving this. EMP, fuzzing and glitching… why not be concerned about an angle grinder attack?
Good luck, and I hope you can do some introspection and maybe find a different, more effective, area to focus on in your quest to improve your situation—from here, this seems exceedingly unlikely to be a good investment in terms of cost-benefit, or even any utility at all.
