MaxHeadRoom
- Joined Jul 18, 2013
- 30,885
Typically they are wound on a former of the correct size on a bench winder and then placed into the slots
I assume you used enameled (thinly insulated) magnet wire for the rewinding. Just checking all possible causes. Also, nicking the wire (damaging the enamel can cause shorts.Thanks but this is for the field, so no slots per se.
When I rewoubnd the field with same gage wire and varnish it moved very slowly so I thought something mechanical wrong - then saw smoke coming out. Wonder what fault will cause this as there seemed to be no mechanical obstruction.
yesI assume you used enameled (thinly insulated) magnet wire for the rewinding. Just checking all possible causes.
So is it wound around the laminations themselves?Thanks but this is for the field, so no slots per se.
I may have wound slightly different no. of turns for the 2 poles. What effect would this have?
You were right! I had said opposite polarity as I was so sure and did not check - which I did yesterday and found that they were of same polarity which I reversed on 1 pole, Tried on reduced voltage and it rotates; will now test on full V.Field Poles same polarity?
