How to restrict current in AC circuit
Status
Not open for further replies.
PICfan
Joined Jan 14, 2011
Hi, i got AC LED rope light, the lights are very bright, want to tone them down, can i reduce current flowing to the LED lights.
Supply voltage to LED lights is 240AC, wattage per meter is 4.8
If i reduce wattage by half i am hoping i can reduce brightness. any practical circuit solutions.
i.e. Simple/Cheapest solution the better.
So really want to try resistor circuit first then maybe Transformer Circuit. then maybe off shelf component.
#12
Joined Nov 30, 2010
18,224
Having a complete lack of knowing how the LED rope is internally wired or powered, I say, go ahead and try. Even if you fail, you will learn about what changes the LED rope will allow and which it won't allow.
DickCappels
Joined Aug 21, 2008
10,661
I do not see a way this thread can remain open and not violate the User Agreement.
Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Any kind of jammers (ie - Phone jammers)
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
