Correct.In that case, if I buy a 35 ppm, 17 L CH4 gas cylinder and then start passing the gas into the chamber, the volume will start reducing. So, if it becomes 12 L (considering 5L of CH4 being passed), the ppm will still be 35 ?
Not quite. ppm is proportional to number of molecule per unit volume.I think I am mixing up in between the 'Number of Molecules' and 'Parts Per Million'. I thought, number of PPM is representing the concentration of a gas indicating the number of molecules present in that gas.
Number of molecules present in the volume of gas you have used or have remaining.Now, if the ppm doesn't change with the volume of the gas, then what exactly is changing with the volume, the number of molecules present in that gas?
That is what your sensor is for. Volume X ppm is proportional to the number of molecules.What is the way to determine the amount of gas (for this experiment it's CH4) present in air and how to determine whether this amount is increasing or decreasing?
Let's say, you have 100 red beans and 100 black beans mixed together. The mixture is 50% red beans = 500,000 ppm red beans. If you take an ounce of beans from the mixture, say 1 ounce = 20 beans, you will likely have 10 read beans and 10 black beans in the volume you take. The mixture you took is still 50% red beans. The remaining 180 beans is also 50% red beans ( i.e., 90 red beans and 90 black beans). The composition of the mixture doesn't change, but the actual number of beans you have changes. Of course, for such small numbers of beans, probability will pay a role and the numbers won't be exactly what is calculated. For gas molecules, probability still plays a role, but the numbers are so large you will never notice a difference.
